More questions
Lit549
I have more questions on my kit.Its a djm 3" lca front,beltec 3-4" rear spring.
Issue in having is raodwalking and bump steer.On a smooth road it holds straight,and kind of bumps and it darts both ways..If I can't find the issue in taking it all off..Do I need to replace the stock upper control arms for the djm ones?Would that help? Maybe I got a bad Alignment but I doubt it as I can let go of the wheel on smooth road and it drives straight.Defintion of bump steer explains my issue exactly..
blurred
Puyallup, WA
Could be the balljoints, uppers might be worn and/or bad angles.
Could be tie rods that are worn out.
Could be a bad alignment.
Lit549
Lit549
Thanks,I'm doing pitman arm Friday ,hopefully that's it..When I took the truck to get aligned the measurements in front were 31.5" (right after install).when I got it back it was 31.25.Makes me wonder if front settled after the alignment?
Lit549
Lit549
I replaced the front sway bar end links and bushings..I also reinspected the front end components and found a little play in pitman arm..Changed that also and it does drive better,but it still road walks a little ..Bump steer is still there but more controlled..Maybe I just need a realignment?
Laurents10
