Cleandenali31
i saw there was one major chronicals post on low oil pressure but I feel I have a slightly different issue pertaining to it.
Recently I purchased a 2007 Cadillac Escalade. 118,6xx miles. When I bought it (as is) from my dealership that is currently my place of employment.no oil change done my by me just yet. It has an Evap valve service engine code, a bad brake switch.... And about 4 days later I had codes on the DIC saying "stabitrac-off/ service traction control)..now the problems begin! The codes showed up intermittently, on and off ect.I took it a mile down the road when these issues worsened and it threw itself into neutral while in drive gear and then threw itself into 2nd gear and wouldn't leave 2nd gear. It got so annoying that I called the dealership to schedule to have it looked at.
Now to the point, The day I took it in, I had it in the garage for 4 days not driven, but the night before I went to bed I had the battery disconnected for 4 days and then I connected it again, took it to the bottom of the hill and back to make sure it was shifting so I can make it to the shop..it was fine..and I mention now that there was no "low oil pressure stop engine" light. The next morning. I get ready to pull it out of the garage and within 10 seconds of starting it it says "low oil pressure, stop engine". This is the first time it's ever showed up. And to me it's funny that it's doing this now after these electrical issues.
The dealership is telling me I need to replace the EBCM to fix the electrical issues and they said that the low oil pressure is a separate issue and straight away to change the oil pump. Not even a process of elimination. I personally think the sensor is bad or something because I know these engines are "bulletproof" or maybe even the sensor filter is clogged or a s***** oil filter and oil. Because this issue never showed up till the electrical issues. Any suggestions. I really don't want to have to deal with 12 hours of labor at $100 an hour for an $135 part jus to find out it's something small. HELP!
