Leveling a 2009 Z71 Suburban?
WildBill
So I'm finally getting around to leveling my Suburban. I'm using a spacer on the top of the strut to get a 2.5 in lift (and I'm adding 1.5 in spacers out back). I'm also adding bilstien 5100s all around. The fronts will be on the stock/lowest notch. I have to buy new upper arms because my ball joints are worn out.
My question is if I go with lifted arms like the ones linked below am I in danger of over extending the CVs at full droop?
Anyone see issues with this parts combo?
http://www.roughcountry.com/gm-upper-control-arms-1278c.html
http://www.roughcountry.com/gm-forged-upper-control-arms-1940c.html
01Konvict
Boats n Hoes
Raleigh/SML
No you will be fine with them not over extending. I wouldn’t go higher than 2.5” on front if you’re 4wd.
jmart157
