Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
ive got a leak coming from the 3joint connector by the heatercore. theres a hose that runs from the water pump to this joint and it divides to the heater core and the auxiliary heater hardlines. its got a bunch of clip fittings, do i need a special tool to replace it? heres a pic
Start with the top hose. . you can press the outside clip things that are on the opposite side of the hose (the yellow things on your picture by the hose) once they are pressed down, you should be able to pull the hoses out
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
