Has anyone relocated their rear view mirror?
GranPrix
I want to drop the rear view mirror about an inch or two but i'm afraid it wont adhere correctly. I did this on another car it didn't hold up. Has anyone else done this?
dbbd1
Mine has two pivot points on the stem off of the windshield. Those would allow you to achieve the same thing, no?
GranPrix
GranPrix
Haven't noticed that, I'll check it out.
GranPrix
GranPrix
Actually i just realized what you mean. That wouldn't work for me. I need it to drop down about an inch or two. I guess i'll try it out and hope for the best and hope it stays on.
PG01
Up here to the right
Just use the rearview mirror adhesive in every store in the world.... make sure you use enough but not too much and let it setup like directions say... you should be good
gat0r
DFW
so your seat is adjusted all the way up, you repositioned mirror down & you still need mirror lower?
if so, then give the mirror adhesive a try
or a booster ;) (lol, sorry had to say it)
Either the OP is wanting to do this because he is really short or is wanting to mount something above the mirror. I'm curious. Regardless, all you should have to do is glue a mount to the glass using rearview mirror adhesive. Just clean the glass very well and use according to the directions. Keep in mind you may have to reposition or modify a rain sensor or wire harness(es).
If you just want to add a second mount, no problem. Just use the correct adhesive like others have said. The only problem I see is if you want to remove the original mount and reuse it. I used to install windshields and have glued many mounts on and once in awhile would get one in the wrong place occasionally. In order to remove one it requires a lot of heat to melt the adhesive and there's a risk of breaking the glass. I used to use alcohol, lit on fire, but the windshield had to be out of the car laying upside down.
GranPrix
GranPrix
I've got the right adhesive and i'm going to lower it regardless. I was just wondering if anyone has had any problems of it falling off later on. I did this to my S2000 and it's fallen off twice using the proper adhesive.
meandmyhoe20
