2011SSVHOE
I'm an egual oportunity offender
here is the video I was talking about in the throttle body thread
Well, at least its running now, right?
WOW , thanks that's the best explanation I've gotten so far. Haven't found much on the google about it but i'm thinking it relatively simple fix. I think i'm going to drive her to work tomorrow I still have the scan tool and I can clear the code if need be.
I hadn't driven her more than a block when the event happened so she was still cold in my opinion.
Big thanks again Chris!!
Good point.No problem.
This scan tool you borrowed- is it just one of those basic pocket "Read/Clear" models or is it an upper-scale model that can display freeze frame data? When a code is set, a freeze frame is stored in the PCM. The freeze frame is a datalog showing what all of the sensors were reporting to the PCM at the time the code was set. If your scanner will show freeze frame data, you can see what the MAF and MAP sensors were telling the PCM at that moment. If one of them is showing something far out of spec, then you can focus your attention towards that sensor and/or it's circuit. FYI: People often are quick to say a sensor is faulty when they get a CEL, partly if not mostly because the parts stores are quick to push sensors onto them. For example, someone's CEL comes on and they go to Vatozone to have the code read. The code says the oxygen sensor is reporting a high or low voltage (rich or lean). Pretty much every time, the parts salesperson is gonna tell them they need a new O2 sensor. This may not necessarily be the case. The O2 sensor could be perfectly fine and was just doing it's job by reporting that the exhaust was rich or lean, which means you need to see why the exhaust was rich or lean- stuck injector, exhaust leak, other sensor reading faulty and making the PCM erroneously over-compensate, etc.
