Getting water in passenger rear door '07 Yukon
KC_JAKE
LEE'S SUMMIT, MO
Whenever it rains a lot, my right rear passenger door fills 1/3 up inside. I have no idea has the water would be getting in there. No leaks or water signs inside the truck at all. I had to drill a small hole at the lower bottom corner to get it to drain out. Any suggestions or anyone faced this issue with theirs?
08grey
There are 3 drains under the plastic molding on the door bottom. They are likely clogged.
Sent from my SM-G950U using Tapatalk
PG01
Up here to the right
Mant threads on here but grey is right... 3 plugs holding rubber gasket on... all car manufacturers have drains in doors... you wouldn’t be able to open window if it was ‘water tight’
08grey
At the edges of the door there is a rubber. Pop that off. In the center there is a oval plug pull that out. Now on the edges on the bottom on both sides there is a round hole. Both of yours are likely clogged with dust and debris. Get a pic and open them up. If you can get Air blow out from the edges twoard the center. Clean out the center plug before you put it back it will also be filled with muck. It has slits in it where the water is supposed to go through.
Off Road Pedia
