edit light settings beyond information center?
malmed
Is there a way to edit the light settings beyond what we can set in the information center?
I would like to change a LOT of mine...
Things like the length of time before the interior lights go dim, or when, and how long the puddle lights come on...
I would like if ANYTIME a door is opened, the puddle lights come on and STAY on for a while....
Even the 90 seconds for the headlights to stay on it too short for my taste, 3 minutes seems closer to correct....
adventurenali92
Big Bear Lake, ca
Puddle lifts are non adjustable as far as I can tell. Unless there is some way to reprogram them within the body control module. Or rewire the puddle lights so they are tied into the dome light.
malmed
malmed
reprogramming the body control module sounds more like what I want to do....
adventurenali92
Big Bear Lake, ca
Unless you have a tech II scanner than i would assume you would have to have a dealership or a shopping with a tech II do it. But I could be wrong.
malmed
malmed
Yes, that seems to be what I have learned reading online, but, even with a Tech2 scanner can I CHANGE the settings to more than 'normal' or not? I have a buddy that can get his hands on a Tech2, but, will I be able to use it for what I want?
caprajohn
