Dropped my Z71 'Hoe on a 3/5 with 22's
westcoast
Salinas,CA
That was a clean tahoe! I had my old 98 just like that but the difference was it was the FTS 9.5 on 36's
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you want that rear end to come down and ride a lot better get the tb springs
DaRosa218
DaRosa218
The Dude abides
Modesto, California
hmmmm did you buy that tahoe like that? I rembember seeing it for sale for the longest time.
Sounds like a plan. I'm going to save up and purchase a set for sure. I know I need the hardware kit but do I need to change out my shocks since I'm running Z71 shocks?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Do you have shock extenders in the rear?
tb springs/djm rear hardware kit is $360 shipped
If your shocks are longer than 22 inches with shock extenders in it wont work the spring will pop out.
DaRosa218
DaRosa218
The Dude abides
Modesto, California
I dont have shock extenders right now. I'm already having the problem with the springs not staying in when jacking up the truck. I have to jack it up underneath the axel so the spring doesn't pop out. I also haven't measured my shocks l. Would the shock extenders solve the spring pop out situation I'm having right now?
Administrator
<~~~thinking the spring popping out is a big issue :think:
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no you have the blue springs you need short 1800 djm shocks.
if you did
tb springs
rear hardware kit
rear djm shocks
$450 shipped
ride will be a lot better
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob but the djm tb springs require different shocks so if your going to change to the tb springs no use buying the 1800 shocks.
if you decide you want to just keep what you have now i have the djm shocks 1800s for 90 shipped
Anas1993
