DRL bulbs that last?
Merc1973
Maryland
Any recommendations for LED DRL blulbs? I got some JDM Astar 3157 amber, brightest one they make with the lens in front. Looked great, only lasted 6 months though. I need bulbs that last longer than that. I even replaced the sockets since i thought that was the proble.m. The sockets were burned and crispy from the PO. Still only a couple leds partially light up. I like the Amber for DRL.
treehan77
TYF Fiend
Crestview, FL
I've had the Aaron ones from Amazon for about 2 years with no issues. Iirc, I had to slightly file to fit a tiny bit. They say backup but I used for drl and used my jtm ones fine in the backup lights.
2Pcs Aaron 6000K Pure White 60W 3157 (3156 3056 3057) Super Bright XB-D CREE High Power LED Bulbs for DRL Brake Tail Backup Reverse Lights https://www.amazon.com/dp/B00HE7SJ7S/ref=cm_sw_r_cp_api_bWmDzb93XSNYG
treehan77
TYF Fiend
Crestview, FL
Th Aaron's I got say application is 3157 or 4114 anyway
Description
Items come with 1 year warranty. Application: 3047 3057 3155 3156 3157 3157LL 3357 3454 3457 3757 4057 4114 4114LL 4114K 4157 4157LL -FOR REFERENCE ONLY -Not compatible with CK sockets. Note: 1.When using LED bulbs for turn signal, you will need to use load resistor or decoder set to prevent hyper flash or bulb malfunction 2.If the bulb does not light up, please reverse the polarities.
Crippin87
I ordered a set of led 4114 bulbs from hidkitpros.com. They were the only true led 4114 bulb that I could find anywhere. The come with a pretty solid warranty and look amazing, I highly recommend them.
bluebear15
wisconsin
I also have these and have had them installed for the past 3 months or so and no issues. Work great. I'd definitely recommend them as they were highly recommended to me when I was looking.
Merc1973
Merc1973
Maryland
Thanks. Not many have long term reviews on these LEDs. I ended up getting the 5702KA (amber) incandescent bulbs which seem to last for years. Regular 3157 do not last long at all and left my sockets melted even worse. I will update when i return back from vacation.
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
I could come up with a great solution if you tell me price range and how bright you want them to be. Oem beam pattern is one of the main features our leds will provide over the cheap stuff. Also beware a cheap Drl could melt the base of the bulb to the socket and create a smog inside the lamps.
TiGrayMSM
