Denali Cluster with Heads Up Display
RB_Trucker
Redondo Beach
Installed a Yukon Denali cluster and HUD unit in my 2015.5 Yukon SLT this weekend. The cluster had to be programmed to my vehicle and to enable HUD functionality. I created a custom wiring harness as the only way to add those connections is through swapping the I/P harness. The rest was just swapping parts.
I love this post! Would love to do this to my 2019 LT Suburban...
Quick questions? I tried researching as much as I could and couldn’t find anything...
I have the forward collision alert with the HUD that only flashes red on the windshield. For this conversion would I only need the Cluster, switches and The harness you mention ? Or would it be all plug and play from WAM ?
thanks again
Page1
Have you had any luck? I'm trying to do the same thing to my 2016 Yukon Denali. I have all the parts except for the connection from my cluster is different than the OEM HUD projector because mine came with the front collision alert.
@GMJay - i have successfully upgraded my forward collision in my '15 Yukon Denali to HUD (Thanks to @cmatt and others) - I am 99% there - I have data being displayed (Default view), i believe I will need WAM to program the cluster to get the other views. I would highly recommend the custom harness, will make your life a lot easier. Also, getting HUD windshield makes a night and day difference.
Page1
thanks again
The FWD collision (flashing red lights) is not a HUD, just LEDs. You would need:
- HUD
- Denali cluster (programmed by WAMS)
- Custom harness
- HUD control
- new driver side vent with hole for HUD control
This is a good place to start
Chris aiosa
- HUD
- Custom harness
- HUD control
Hi I’ve got a 2020 Tahoe rst edition looking to do this upgrade. I have found most of the parts not purchased yet but do they make a Tahoe digital cluster so it’s blue? Also anyone know how to make this custom harness for The hud display and what parts need to be change out to fit it?
Chris aiosa
@cmatt any help?
JVega
