clicking noise coming from the relay
stuntmanray385
all of a sudden in my truck im hearing the clicking sound like the turn signals are activated constantly. it goes in and out. turn signals work fine as well as hazards but it just clicks like if they are on. anyone kno what would cause this?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Try removing fuses #2. and #4. Does the problem go away?
---------- Post added at 10:27 AM ---------- Previous post was at 10:23 AM ----------
does the clicking sound stay gone if you remove the flasher unit?
stuntmanray385
stuntmanray385
yea when i remove the flasher it stops. if i put my hand on the flasher relay i can feel it clicking. what are fuses 2 and 4 connect to?
SunlitComet
OBS Jedi-Do Good
Your multi switch is broken. About $200 for a acdelco unit. And you will slightly dissemble your steering column to do it. There are contacts in the switch that control power to that flasher.
---------- Post added at 11:49 AM ---------- Previous post was at 11:47 AM ----------
#2-4 were for the 4x4 system. Sometimes a malfunctioning transfer case or shift motor can make the t-case computer go into a relay frenzy and kill you battery. Just wanted to check.
stuntmanray385
stuntmanray385
yea it not constant. it goes in and out..that sucks...so how long do i have til my turn signals go out?
willb
