Blown head gasket/Cracked head/tired of mechanics
dubyagee01
My 2000 does it sometimes. I keep a key from another truck that fits but wont turn the lock. I put it in and work it back and forth then start it with the right key. Works every time.
Sent from my iPad using Tapatalk Pro
bigfootchiro
bigfootchiro
Largo, FL
Interesting! I’ll have to try that next time.
bigfootchiro
bigfootchiro
Largo, FL
So turns out, valves were still too tight. I can’t believe how tight they were, considering the procedures we followed. Now adjusting them with the valve covers off, and it’s waaaaay easier! Doing passenger side tomorrow. Only problem so far I think is with the distributor. I can’t seem to get it to set down with the metal tab pointing at the 8 mark on the distributor. I’ve got it close, but it’s a hair to the right. I’ve been messing with the oil pump to adjust this, but I’ll move it just a tad, and the tab will move halfway to the flat surface on the housing. At idle, the timing is at -22. Haven’t risen to 1100RPM as the valves are still being adjusted. Hopefully after valves are all adjusted, it will smooth out the idle. Any tips or tricks would be great!
randeez
south florida
I think the slot in the oil pump also lines up with the distributor rotor, with a long flathead point the oil pump at cyl 1 also. note which way the cam gear and distributor gear mesh, when you set the distributor in it should be a few degrees CCW (or whatever is meshes) so when fully meshed and bottomed out it'll be pointed at cyl 1. there shouldnt be any timing advance at idle maybe a degree or two. but if you've got the oil pump and everything lined up you will leave distributor clamp loose and turn the entire distributor while the engine is running to get the timing set
bigfootchiro
bigfootchiro
Largo, FL
So I can’t seem to get it past -16 to -21 timing. Wtf? Between the last two days I’ve probably spent 3 hours just messing with the distributor
bigfootchiro
bigfootchiro
Largo, FL
bill99874
