33” Tires 2015-2020 Yukon
Logangiesbrecht
Hello,
I’ve got a 2016 Yukon XL Denali. Previous owner removed the Magneride suspension and replaced with FOX 2.0 (I believe coil overs).
My goal is to fit 33x12.5” TOYO MTs with as little suspension work as possible, ideally none. I want the tires to fill the fender but I realize this is difficult with the shape.
Has anyone attempted/ succeeded at this? What specs did you find to work and what did you have to trim.
I’m aware I may be forced to have a 2” level installed but if I’m able to avoid this then I will.
Thanks for any advice you may have,
L
(Picture of my rig. Stock 285/45r22s)IMG_9274.jpegIMG_9273.jpeg
K2 Kaiju
The Depths
Check out lifted suspension section. Some can put on that size on stock wheel/hight, some cant. Level doesnt allow more tire clearance on these as you still have to deal with rear of front wheel well rubbing on turns. Mine was really close with same tire size you have now...
Dukk
