2008 Hunting for gears
Philpug
I understand the transmission on our 08 feels like it is from the Jurassic era but on long climbs the hunting for gears is frustrating. Ideally I would like to put a more modern transmission in like the later 6 speed that was offered but I don't think that is feasable. Do I have any other options?
You could get a tune, which I believe would also adjust your transmission's shift points (At least, it did for my 07 Yukon XL Denali, with its 6 speed transmission, and the difference was about as significant as the tune to my motor.). Give @BlackBearPerf a call and discuss your needs. If they can tune your transmission, the difference could by huge.
wjburken
Eastern Iowa
In addition to what @Joseph Garcia mentioned, might try and put it in tow/haul mode abs see if that helps with the gear hunting.
Bill 1960
Testing the Limits
Regearing your axle(s) would be another option. Expensive.
And don’t expect a transmission with more gears to shift less. Quite the opposite actually. The shifting is less perceptible because the RPM changes are smaller, but there’s more of them. I had a Colorado with the 8 speed and it would drop a gear at the slightest incline. Two or three on any real grade.
A tune can help you for sure, by raising the throttle position threshold for a downshift. But it won’t be a silver bullet.
Philpug
Philpug
I am not expecting a silver bullet...well maybe I am. I do know that when we had a rental 18 'Burb it was much more of a pleasure driving over the passes of eastern Nevada than ours. The multiple gearing changes 1K RPMs not the 2-3K that it feels ours is doing now.
Tiki
You’ll have that with a four speed transmission. 6L80e is a big upgrade in my opinion. To me it would be worth finding a newer vehicle with it installed as a factory option, but because they were used in that body style I reckon you could find a way to swap it over with used parts on the cheap!
Torque is your friend in the mountains.
thompsoj22
california native "REPUBLICAN" high desert
What engine do you have? Downshifting with a steady throttle position on a climb is normal 4L80 function, 2 to 3k rpm is the norm with the 4.8 or 5.3. We traded in our 2008 4.8 tahoe for the exact reason you are describing, And that was after i changed the rear end from 342 to 373. It made a difference but not enough to make us happy.
Philpug
Philpug
We have the 5.3 w/ 3.73 rear
