ss4chad
Fort Worth, TX
What is a Italian tune-up?
Per the BING Co-Pilot:
An Italian tune-up is an unconventional method of car maintenance that involves driving at high RPMs to clean out carbon deposits from the engine.
Hmm, I thought it had something to do with pouring Red Wine in the gas tank? Looks like I learned something today!
Chad
K2 Kaiju
The Depths
Chad
Yes - you do several full throttle 0-60 (+) runs to get the engine heated up and knock loose all the crap. It can be bad if you have a weak link somewhere, but every time I have done it the engine runs a lot smoother...
Jeff_
Scottsdale, AZ & N. Idaho
Well I ripped apart my interior and installed my Kicker sub. Followed every single instruction exactly.
Turned on some music and the sub itself makes no sound..
I'm unsure if it's because I need to go to the dealer and have them eliminate the ANC (active noise cancelation) through a reprogram. I know the installation manual says to do that. But I figured it would still work somewhat before having that done and then just be optimized after that was disabled.
Fingers crossed that all I need is the quick trip to the dealer and to pay $50 for them to reprogram in order to get this sub to function..
(pic of things torn apart for your enjoyment)
Chad
lol, I do those every day!
the ANC shouldn't stop the sub from working, all it would do is cause some undesirable feedback, kind of like having a mic to close to a speaker and instead of a high pitch squeal you would get a rumble. double check your work.
Cryptothedog
Also blacked out my rear emblem. I need to redo it though. I messed up on the cutting of the vinyl.
