TheAutumnWind
The rain put a damper on what I had planned, so I went through the front end, and lubed all of the zirks that I know of with Valvoline GM approved red MP lube. Refreshed the CV boots with Sil-Glyde, this stuff workd great on re-conditioning rubber. I would have used it on the ball joint boots, but they are too weathered and cracked to the point that using it might cause them to come apart. Will do some research soon on the best ball joints and tie-rods soon.
You using silglyde sg8?
RyanJW
Palo Alto
Put another set of shocks on today... this time I put on the Bilstein 4600's along with the HD spring in the rear. It is significantly better now! I don't feel like I am twerking as I am driving down the road anymore! Replaced the front jounce bumpers while I was in the front.
I also replaced the front sway bar and end link bushings with the Energy suspension PU bushings, and I used glorious amounts of Formula 5 when installing them.
Sounds great! I've got the dreaded rubbing noise when going over a rough dip in the road or a speed hump so I'm thinking about doing the whole lot of shocks, sways, bushings. Any suggestions?
95escahoe
Over the weekend I got the passenger rear outer Denali door handle on, color matched looks so much better and scored these other handles off FB hopefully have them on the end of the week
05Single
afraid of the dark
Ptm ftw:thumbsup:
00'BlueSteel
Carolina
Looks good man, love the wheel and tire setup. Makes for a great stance.
Pilot
Brooklyn, NY
Shot some video of the latest mods this weekend.
In other news, check engine light is on and computer is throwing P0302 code (cylinder 2 misfire for those who don't know). Going to take it to the mechanic in the morning. Maybe the motor is shot and I need to swap it with a tuned LS3? :D
BWASTEEZE
