Front Dash Crack
Brooklyn hoe
Does anyone know if a dash from a 2012 chevy avalanche will fit a 2007 tahoe, found a good one same color for a fairly good price.
okfoz
I believe they are the same... Or similar enough... What you can do is this
Go to a GM dealer webstite I checked gmpartsdirect, here is what they gave me.
23224747 - 2007~ EBONY, Tahoe, Yukon w/o denali
23224748 - 2007~ Cashmere. Tahoe Yukon w/o Denali
What I can figure it fits the following:
2007-2014 tahoe, Yukon (W/O Denali) and Suburban
2007-2014 Avalanche
2007-2013 Sierra & Silverado (1500)
2014 some Sierras & Silverados (2500 & 3500)
With the exception of the Cadillac and the GMC Denali, it fits Pretty much everything from 2007-2013 and some of the 2014's
Old GM PN: (Black) 15915972, 20896285, 15853749, 20782064, 20989630, 15823878, 15892887, 20959607
YukonCrazy
Raleigh, NC
I assume cashmere is the same as cream or tan, which means I am looking at 23224748? That's around $350 gmpartsdirect. I wish the page on gmpartsdirect would list the color.
Brooklyn hoe
Thanks that helps do you know how much the stealership charges to swap it out or is it something that I can do.
Govtahoe
@Brooklyn hoe probably your first born. But I've heard it's a b**** and a half to do. Someone had mentioned that the dealerships were running a deal on first time replacements. Not sure what the price was. Vague memory, may have dreamed it
YukonCrazy
Raleigh, NC
I just called my local GMC dealer and asked for a quote to replace the cracked dashboard. He gave me an estimate between $950 and $1100.
Thompson Buick GMC Cadillac
Raleigh, NC 27609
YukonCrazy
Raleigh, NC
I also called another local GMC dealer and was quoted $810 just for the labor (6 hours).
Hendrick Chevrolet Buick GMC Cadillac Southpoint
Durham, NC 27713
Update: He called back with a better quote (part+labor), which is around $1,300 with tax.
Skatejosh369
Wonder how true them replacing it for 100 is. I called, they will be getting back with me. My father in law used to run the service department at the dealership I called, so they always hook it up.
GBRacing
Add me to the list. I have 2007 Tahoe LTZ and notice a massive crack on top of cluster last week. After doing a little internet research, like 2 seconds worth, I found that this is a very common problem with little to no solution. Well, other than paying big $$$ and the potential of it cracking again after few years. Just like the motor mount I had replaced an already needs replacing again. Argh!
fishcop076
