DWebPro
Stevenson Ranch, CA
Figured out how to wire up the DRL/Blinker with switchback LEDs. I took pictures and will do a write up. Will post more shots later in the day when the sun goes down some.
Next is new headlight housings and a HID Projector retrofit.
Also in installed slim 12" sub in the back and an amp under 2nd row captains chair. Can anyone tell me what is best to use to cut the floor cover under the captains chairs?
https://www.youtube.com/watch?v=O6OjKAc9e0o
08grey
Drill a starter hole trace out the amp and use a jig saw.
Joew311
TX
I cut a piece of plywood and wrapped it in carpet to mount my amps. I made it fit perfectly so when the seat is down it's captured by the seat. I ran all of the wires through existing gaps and holes in carpet underneath the board and through holes I drilled in the board.
63Blackseries
Canada
Eibach swaybars coming on Wednesday!!
@Bruizza do you know if corvette servo work for all years? 2013+ with 6speed if they do i may probably order one too.
d-alex-l
You needed more bass? :wtf: I get more than I can handle with the kicker door speakers and a little equalizer tweaking..
waiteben84
