You're sub amp bro.. In your sig it says 1000 watt Alpine amp.. Alpine's 1000 watt is the PDX-1.. I ask this to make sure you dont have a 250 or 300 watt Alpine amp that says 1000 watts (peak power) on it.
Go to best buy, or similar store, and you'll see what I'm talking about. They claim 2000 watts!!! but they're like 200 RMS. They overrate the amps. They'll rate them at 1 ohm or even 1/2 ohm at 1 channel (or for a multi channel amp, they'll give you the bridged power rating.. and then divide it by the resistance.)
So.. if you start with 1000 watts at 4 ohms.. then they'll claim 4000 watts at 1 ohm (or start 1000 at 2 ohm, and rate at 2000 at 1/2 ohm)
The w7 is a 3 ohm speaker. The JL 1000/1 is a true 1000 watts over a range of 1.5-4 ohms. The PDX-1 is rated 1000 watts at 1 - 2 ohms. If this is the amp you have it's still PLENTY of power for the w7
Either you have a smaller Alpine amp, or your PDX-1 is broke
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
---------- Post added at 02:26 PM ---------- Previous post was at 02:24 PM ----------
Is this your amp?
http://www.crutchfield.com/S-pT6ihdqHUJL/p_500PDX1100/Alpine-PDX-1-1000.html
---------- Post added at 02:29 PM ---------- Previous post was at 02:26 PM ----------
Or is this the one...
http://www.crutchfield.com/p_500MRP1000/Alpine-
MRP-M1000.html?tp=115
