iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 685
- Reaction score
- 372
you sure thats not just the brake pad sensor tab thingy that rubs when the pad is thin?
On the back before the front tho?
So, you are original owner and know the brake maintenance from day one?On the back before the front tho?
No I’m the third owner.So, you are original owner and know the brake maintenance from day one?
Typically, most rigs/trucks will wear the front pads twice as fast as the rears. The fronts do most of the braking when applying/using brakes.No I’m the third owner.
I would just assume if you change your pads, you change them all
So far, I’m thinking it’s a rock stuck in the rotor and back plate, or the wheel bearing is going out.
Most folk fix things as they break. There was definitely a time when if the front brakes were squeaking I wouldn’t even ask to have the back checked. I’m a different person nowNo I’m the third owner.
