Tonyv__
Bucks county PA
Is this on your rear doors? I have it in the same spots on my rear doors.
Ultimately I think the bigger problem is the door alignment which is causing enough contact with the door and the rubber door seal on the bottom to rub the paint off over time.
Yeah. Wasn’t sure if it was common or if I have bigger issues lol
Administrator
Any of you fine folks need some new rotors for the rear of your rigs??
RST Dana
OH
Price?
LT1ZOB
This was happening on my 16 rear passenger door. I touched it up, put a piece of xpel over it, and that did the trick.
Thrust
ICT
Added Hellwig rear sway bar end links to my Hotchkis sway bar. Do yourself a favor and ditch the factory end links.
Also bled the Brembo calipers using a snap on diagnosis tool to energize the ABS valves. Seems to have done the trick as the brakes work great.
Sparksalot
Bastrop County, Texas
Got some crossbars for the rack. some assembly required.
SpyShops212
Took it to the dealer in Houston called SeWell Cadillac to have the OEM windshield replaced and the bottom outside trim under the windshield which almost all K2XX trucks get warped. If you anyone goes and check you will see what I am mentioning. I figured it would be the proper time to replace the trim piece while they are at it. I will pick up tomorrow and post to let everyone know how it went. I did make a video and took lots of pictures just in case they mess something up. I also noticed on my previous windshield that there was spots that you could see everywhere when the sun hits it.
