nick14226
- Joined
- Nov 22, 2019
- Posts
- 211
- Reaction score
- 210
@STORMIN08 do any of your stock suspension pics show the slack In that brake line at full lock? If so, please share.
If done properly with a reputable kit..all works as did stock.
Also from expirience...I would rather have a lift that keeps as much geometry as stock.
Ie...a 4-6 " lift the uses a drop cross member, preferably longer struts, coils and shocks
Keeping stock parts and using extending bra kits I purely for on road looks.
I may do a 2-2 1/4" front level, but even at 1.5" my 2011 tahoe never aligned correctly
Without looking up specifics...there is a 4" that only drops the front diff for shaft angles.
For me, that is too much lift with put correcting A-arm angles.
Secondly, some replacement upper arms recommend or require a different off set wheel (seey pic again), as the tubes are larger diameter or on slightly different approach angles.
When exceeding *** amount
( tahoe/suburban being 2-2.5" max), I would prefer to see a drop crossmember Lowering the lower arms, and providing a longer knuckle to keep stock a arm angles and ball joint angles.
The new knuckle being longer (outside wheel barrel) and thick generally requires a different offset wheel.
That off set could be
1. New wheels
2. Spacers (I do not recommend)
Doing your homework now ensures a correctly performing vehicle, nice ride experience and No quick for sale signs.
