Bombsquads 05 Denali build..... sorta
adventurenali92
Big Bear Lake, ca
It was awesome. Soap was so thick I could see the dust and pollen (no dirt I washed it a few days ago) slide right off. I will definitely be using this a lot more. I only ordered the 16oz bottle of soap cus I wasnt sure if I'd like it but I will be ordering the gallon. I got the honeydew soap
Yeah I buy it by the gallon from them. Haha. I like the honeydew but I also really like the watermelon snowfoam soap as well!
Bombsquad85
Bombsquad85
Northern VA
Those look great, love how they match the calipers . Gives me an idea for mine:hmm:
Thanks ma . I'm over all pretty happy with the truck. Now if only I could figure it why the CEL came back on for the knock sensors.... i just did this job
Did you use AC Delco sensors? If not, that’s most likely the problem. There’s been a lot of failures on the aftermarket ones.
Bombsquad85
Bombsquad85
Northern VA
I did. Ac delco sensors, felpro gaskets. I'm thinking it's the harness I didnt go with OEM I think I went with dorman
I used the Dorman harness without problems, haven’t heard of any issues with those.
Bombsquad85
Bombsquad85
Northern VA
I'm not sure what it could be. I did the TSB with building a dam and used what I thought was good parts. Torqued everything to spec.
It wouldn't be a big deal if the install wasnt so damn lengthy
Yeah, those are buried pretty deep. Damn.
Bombsquad85
Bombsquad85
Northern VA
Changed out my front Wiper fluid motor. While the truck was up (had to lift the truck to get access to the motor) I took the time to grease the tierods and ball joints and found this....
Looks like I need to get a new axle and possible another control arm.
Does moog have a warranty? Or does it matter if I have ac delco on one side and moog on the other?
Yote1
