Battery or electrical.
Dan2002
2002 GMC Denali
I recently found an issue with my vehicle
The past 3 days I have been driving at high speeds. I noticed when acelerating hard the battery volts gauge drops. And the lights on dash start flickering. The radio turns on and off. Battery light comes on.
After a stop or red light. The volt gauge comes back up to normal and all light stop flickering.
I thought maybe my battery is no good.
Well yesterday when driving back home. It started to do the same but this time the light and all dash components stopped working. After driving around 4 minutes. It started to lose power eventually driving about 10MPH. The dash showed "reduced engine power".
I managed to make it home. After waiting about 10 minutes. I decided to give it a look and started it and drove it around the block with no problems.
It seems that I lose voltage going at high speeds 60MPH +
So, did you replace the battery? Does it happen if you rev it in neutral? Just trying to determine if it's RPM- or load-based. My first suspicion is failing alternator or even the belt slipping at higher RPM.
if you have a autozone near you they will check your battery and alternator for free, I would also check for a bad ground
Martinjmpr
Littleton, Co
I would suspect the alternator or a bad connection. As ^^^ said above, it's easy to get both the battery and alternator checked at any auto parts place. If your alternator is bad you can replaced it in about 1/2 hour or less with basic hand tools.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I SECOND MARTINJMPR, I DOES SOUND LIKE A ALTERNATOR PROBLEM.
adriver
Your alternator just keeps your battery charged, while your electronics are run off the battery. Yes, I know It theoretically will run your system, but that's not how its supposed to work. If your alternator fails, your system just runs off your battery and drains it until it dies. I'm not saying it couldn't be the pulley, but I don't think its the electrical aspect of the alternator; unless someone knows if maybe a diode went bad, causing a surge or voltage fluctuation. I noticed you recently needed to replace your motor mounts, was there any kind of problem with that, (your hard acceleration)? What is your voltage fluctuation? Is this happening at a specific speed or rpm? Can you manually shift lower and get it at the same RPM? I'm thinking its something mechanical, maybe a loose belt tensioner or belt slipping somehow.
06JET
Wisconsin
Had a 98 GMC 3500 once that the battery terminals would corrode every 3 months no matter what I did. When it would happen the connection would get bad and the computer would act crazy. Once the trans stopped shifting and was hung up in 1st. I removed the cables and let the computer reset and everything was fine. My truck would not run off the alt. If the battery completely lost connection the truck would die. It was the times that it would still get a few volts thru a bad connection that screwed everything up.
D
Dan2002
I did tried a new battery. But wasn't actually new. It's like 2 month old battery from a 03 suburban. But it was a dead battery. I tried to jump it but my Denali didn't stay running. Maybe it's completely dead. I will get a new battery possibly tomorrow and try it
Matahoe
Grand Rapids, Michigan
More than likely hidden corrosion on the back side of the battery bolts. Once you get both battery cables disconnected you will want to remove both bolts and plastic boots from the cable terminal end. Then you can go town with electrical cleaner and a wire brush.
Also, you can disconnect the alternator single wire (tape it off) and 2 pin harness to rule it out. There isnt any problem running the engine on just the battery.
D
Dan2002
I bought a brand new battery and it seems to not have changed at all. Battery boltage on the gauge begins to drop when reaching 2000 rpm's. At night I can see my lights to dim a little bit and if I keep acelerating I get the battery light on the message center screen.
Could it be alternator issue? Or something electrical
