Console doesn’t work
SoCalTankerDriver
2004 GMC Yukon XL, over 100k Miles. I previously posted about an issue where
PRNDL are barely visible, now we are experiencing the entire console (gauges, Speedo and tach) not working for some time! Anyone have an idea of what I can look for? Is this a voltage thing? It is irritating to say the least.
HiHoeSilver
Away!
Chicago
Is the cluster not functioning at all, or just not lighting up? Do the needles move?
adventurenali92
Big Bear Lake, ca
Do they randomly shut off all together? Or are they just permanently dark or dimly lit? If the first is the scenario, you might try replacing the dimmer wheel/auto light control switch. My close friends 2005 Escalade esv, cluster would go dark at random times, sometimes over a bump and sometimes not, but whole thing would go dark and well as the back lighting on the radio. I found online it could be the dimmer wheel going bad since we could fiddle with the dimmer wheel and bring the lights back on. He replaced the switch and so far so good. If your whole cluster is dim all the time, then it means the back lighting in your cluster is shot. Which is pretty common in this generation truck. @ScottyBoy rebuilds them professionally and his work is hands down the best! He can put in new LED back lighting as well as put in the better stepper motors for your needles. He put together a write up thread documenting the process on upgrading an Escalade cluster I sent to him that’s now in my Yukon Denali with blue LED lighting. It’s pretty spectacular and a really cool upgrade if the lighting in your cluster is shot.
SoCalTankerDriver
SoCalTankerDriver
Doesn’t function at all. No lights, needles don’t move and no gauges. Sometimes the console comes back to life in a few minutes but the other day it took about 20 minutes!
SoCalTankerDriver
SoCalTankerDriver
The entire cluster after engine starts doesn’t function, sometimes it comes to life in a few minutes but the other day my wife drove it and it took 20 minutes before it came to life
Forrest0125
Dallas, TEXAS!!
Ugh i have a 2004 tahoe and just went through this..... I hope its a ground for you. Me not so lucky, for some reason mine had a disconnect where the pins for the connector were. And unfortunately it was in the plastic on the board side. The plug goes in then the pins make a U shape through the board and onto the face and somewhere in that U i had an intermittent connection.
Xay2Smoove
