WestCoastie
- Joined
- Jul 9, 2023
- Posts
- 32
- Reaction score
- 43
1st post - probably should have been in introductions but I need help fast.
I have an 2003 Yukon XL 1500 with the 5.3.
Bought it with just under 100k miles the beginning of last year.
After about 10k miles started to get a battery light and random small issues (like fuel gauge bouncing). Cleaned up all the grounds I could find (chassis/engine). Battery light faded a bit but persisted. Battery eventually wouldn’t take a charge. Replaced the battery and alternator. Battery light faded almost all the way but wasn’t quite gone.
immediately after this engine developed rod knock. Drove less than a mile after.
Truck sat for 6 months until I was able to rebuild the engine.
Rebuilt the engine, almost stock. Did a few mods for oiling and oil pressure and installed LQ9 cam. Engine fired right up and runs smooth.
Everything was good until all the electronics in the cab stopped working. Engine light came on and so did blinker lights in cluster, they both stayed on solid whether the key was in or out. Also, all gauges were frozen where they were when problem occurred.
I disconnected battery and weirdness went away. Until, I turned the truck back on. After about 30 seconds electronics stopped working again and blinker lights came on again. This time when I shut the engine off it over-ran/dieseled. That junction under parking brake lever has a relay that is making a clicking noise and the IGN 1 relay under the hood is clicking as well.
Even with electronics not working engine still turns over and runs. Thought occasionally it stumbles and sputters and now always over-runs.
I’m thinking it’s the BCM but I have no idea. This is definitely the strangest issue I’ve ever had in a car.
And before anyone says anything, I have used the “search” function a lot but nothing seems to really come close to what I’m dealing with now. Any help would be appreciated.
