bottomline2000
Dallas, TX
That right there is the reason I do all my own work. There's nothing that pisses me off more than paying some outrageous price to have someone work on my rig, only to find out later they didn't do it right so it needs to be done again. And usually it happens way away from home so it's even more frustrating and expensive. Good thing you happened to be installing the wheels.
I've found that shops don't like to use torque wrenches..warped rotors at 5k miles due to overnighted lugnuts.,I do make it a point to bring my loud ass tahoe thru they service drive and leave it there to get air filters since wix don't fit it..pisses off the svc manager..same dealer told me 0w20 oil will kill the engine even though the manual calls for that weight oil..they insist on 5w30..I literally have an out of town shop service it now..!uck dealerships.ca2aac8b9dd47e3dbd2640b267fb5d3b.jpg
ScottyBoy
Shreveport, La
Small update. Picked this cluster up from a member on here. Had Scott put led's in. Also ordered led 3rd brake and tail lights for it. 74bbb67cfe5e423ca52e386cce6cf385.jpgf47da896819cd69a2e7d8fabfece54aa.jpg
Sent from my SM-G928V using Tapatalk
It looks kinda purple in pictures, but that thing looks AWESOME in person! It's really bright blue.
Swapped to the 22's today. Gotta get used to them again. 20180617_140544.jpg 20180617_140554.jpg I also fixed the dip on the bumper from the trans fluid mishap.20180617_140642.jpg I also figured out a good way to mount the bowtie center caps. Screenshot_20180617-151339_Gallery.jpg Now I gotta figure out why when my ac is on high, it vibrates. I feel it through the gas pedal and steering wheel.
Scottydoggs
NJ
not the tahoe, but my regal. i did the wb wire through the egr on it already.
today was the regals turn. got my wb wired to hpt.
i did some re tuning after it was falling on its face about 90 mph at the track. pretty sure the zero'ed out pe time vs rpm folder let it go lean, some maf tuning at its holding its afr much better, then i installed the large meth jet for fun kinda, just wanted to see if it was to much or not, dont ya know the engine loves it.
no kr at 19 wot so i need to put it back to 21. af holds steady at 11.2 wot now.
