Back window rattle is annoying!!!!
yukonchief
What are you all doing to solve that little back window rattle that goes off every now and then on certain roads? I bought a used 2017 Yukon and noticed this on some roads only but it’s annoying. Thanks for the ideas
dbbd1
First I've heard of this one. I don't have a rattle. Maybe adjust the catch for the window a bit?
sickk23
New Mexico
Do you mean “have NEVER heard of this one”?
I never had a back window rattle or any rattle luckily.
dbbd1
Never had a back window rattle or any rattle luckily.
Both, for now. I'm sure my dash or other parts will eventually develop some annoying noise though.
Grizz
I too just purchased a 2017 Yukon and am experiencing the rear window rattling periodically.
RST Dana
OH
I had an 08 and 13 that both had back window issues, but only when towing a 12 foot enclosed trailer. I finally, added some oil/grease to the rubber posts and it seem to help the squeaks go away.
Alexquade
Crowley, LA
Different body, but my 2011 was randomly doing it and it was the third brake light. The three plastic screws that hold it in were a good bit loose. Tightened that up and problem solved!! Good luck!
Matt H
Long Island
My 2015 has had a squeak/rattle (more of an annoying squeak than a rattle) in the rear since almost new. Dealer of course could not re-create it, although it does not occur all of the time. After some poking around, I think it is coming from the rear spoiler. I have been planning on separating the two pieces of plastic and seeing if I can insert some type of gasket material to keep the pieces from rubbing together...I just haven't found the time yet!
DarkHearse
