Traded in tha hoe, suburban build!
kbuskill
NE. FL.
Drivers side wheel well under the hood below the fuse box above the strut is a big gray relay and connector, this is for the air compressor. Lay your hand on it and have your wife turn the key to the ON position and wait a few seconds and see if you hear/feel it click.
You can also unplug it and jumper 2 wires together to power the pump. If it sparks when you touch your jumper leads and the compressor doesn't turn on then your compressor is shot.
The computer commands the dump solenoid valve to open before engaging the pump so the compressor doesn't draw as much amperage and is easier to start up initially.
Are you getting any service suspension messages on the DIC?
kbuskill
NE. FL.
Also, I just went through your build thread.... nice Burb, looks great!
C
crazycrew
Vacherie, LA
Thank you. And no, no dic message or lights. I will try that when she gets home. I did see the alc relay, but haven't checked that yet.
C
crazycrew
Vacherie, LA
Ok, so still haven't checked for any soft codes (no dic light) I did just try putting direct power by jumping on 87 & 30. No go, guess I'm buying a new ******* compressor [emoji34]
C
crazycrew
Vacherie, LA
kbuskill
NE. FL.
Did it spark when you jumpered it?
If not did you check for power at the relay harness?
C
crazycrew
Vacherie, LA
No, no spark that i remember. I'll need to get a test light and make sure. I'll check that tomorrow night after work.
kbuskill
NE. FL.
I would definitely check to be sure. Nothing worse than buying new parts only to find out that wasn't the problem.
Xay2Smoove
