BADRIDES
- Joined
- Dec 18, 2015
- Posts
- 1,730
- Reaction score
- 1,139
I have a pair of Nivomat shocks for sale if anyone needs any that came off of a 2002 Tahoe.
My car has a 3” drop I’m hoping after I replace the ZW7 shocks to Bilsteins 4600 I’m hoping the rear doesn’t sag to much. From what I’ve gathered at the shop was it drops about 2” if so I think it might be perfect seeing that my front sits a few inches lower than the rear.Late to the convo, but just thought I'd share my experience.
I just replaced the Nivomats (ZW7) on my 2002 Yukon yesterday. I'd say I lost at least 2 inches on the rear end height. I replaced the Nivomats with a set of Monroe Reflex Monotubes. I'm pretty disappointed in the overall appearance of the vehicle, and frankly, I can't tell much of a difference in the ride. My Yukon has almost 200k on it, so I assumed there was no way the Nivomats were still working, but I don't know how to test that assumption. Now that they're off the vehicle, is there any way to tell if they're toast? I can't compress them with my bare hands.
I'm now considering taking the Monroe Reflex Monotubes off and buying the AC Delco Self-Leveling shocks off of Amazon. I guess the other option is to buy some new springs to try to raise the rear end. Has anyone had a positive experience restoring the original height of the vehicle by installing new springs?
Thanks!
I have a set of Nivomats for saleMy car has a 3” drop I’m hoping after I replace the ZW7 shocks to Bilsteins 4600 I’m hoping the rear doesn’t sag to much. From what I’ve gathered at the shop was it drops about 2” if so I think it might be perfect seeing that my front sits a few inches lower than the rear.
If you're not having any issues--then no.Have an '02 Yukon, 180000 miles, mine seem to be fine, no leaks, no bounce and no sag when I hook up a 23' boat. Would you change them "Just Because"?
I have a used set of OEMS for sale off a 200292k miles on a 2005 and mine apparently went out this week after a couple of days of negative temps.
Vehicle rode and drove fine on Friday, then after -5 degree night, it felt weird and the back bounces up and down. Let it sit a couple of days in warmer weather and drove it and still bad.
Never seen shocks go bad overnight!
Definitely not going with OEM and will likely get the Bilstein set up.
