I need some advice/ info/ prayers for replacing a brake line.
TURNz
2001 Tahoe 4wd
This morning i blew the main front to rear brake line. Above the frame, by the gas tank.
I'm not sure where it starts or ends. I can't even see it, i can only touch it.
No lift, so i'm working on the ground. I assume that i have to buy a straight piece and do the bending, cutting and flaring. I can't drop the tank, so i'm hoping I can reroute it outside the frame rail.
Any thoughts here? anybody do this already and have the secret? I don't have the money to take it to a mechanic.
UrbanSuburban
sorry to hear about your trouble, You have got to be very careful when replacing this line, it will come from under the drivers side door and go straight back on top of the frame rail. Under the drivers door is the Abs Pump, it has five or six connections depending on what style of abs you have, it does sound like the five though. You don't have to put it on top of the rail as it can go on the outside of the frame near the top. It will go to a cross frame under the spare tire and connect to a tee junction. you will have to do some contortions to get it down. Usually the rubber hose that it connects with is shot as well. Be wary of the ABS pump as getting those fittings out can be a problem.
Make sure your caliper bleeders will come out or you will need new calipers. Good luck with it
UrbanSuburban
I did the complete system on my suburban and got the complete package which was stainless steel from Dorman at Rock auto. 45 dollars which included the fittings.
TURNz
TURNz
i found dorman (919-152) and acdelco (22933217) on amazon. Is one better than the other?
95escahoe
The Dorman one is SS and the GM one is just coated brake lines
TURNz
TURNz
I only found acdelco on Rockauto.
I guess ill go stainless with Dorman from Amazon.
Sent from my SM-G935V using Tapatalk
HiHoeSilver
Away!
Chicago
There is a great video out there on you tube of a dude showing how he sneaks it in there through the wheel well without dropping the tank. He had a dark red nbs tahoe if memory serves.
TURNz
TURNz
Yep, i watched it. Hope it works for me.
HiHoeSilver
Away!
Chicago
Good luck. Take pics and let us know how it goes. I had thoughts of doing mine while the tank was out for a pump, but had to keep schedule... Know it's coming one of these days.
TURNz
TURNz
I sprayed the joints. Of course it has to be the highest one on the ABS unit. Not sure how to get to it.
And the rear seems to meet a union where the rubber hose to the rear diff is.
Its above the spare tire cross member. I can't see it, but i can touch it.
Not sure how that's going to go. It doesn't feel scaly, so maybe it will come out ok.
Im headed to buy the proper wrench, but I'm wondering if i can even get a wrench in there.
DarkHearse
