$700 for rear tail light replacement???
L's Truck
DC Metro
UPDATE: gotta love the dealership. Took it on a roadtrip and it was intermittently working. Removed it (very easy) to check the connections - nothing there. Opened the fusebox, found the correct fuse, pushed it in all the way, voila --- it works. Hmmmmmmmmm
Stealership never ceases to amaze me
NathanJax
Vacation Nathan
Administrator
Jax, Fl
:lol2:
Glad it worked out.
Kazsmir
I filed a complaint with the NTSB... I have 52k miles on my 2015 Yukon XL Denali... taillight is temperamental. I can push on the plastic housing and the taillight will illuminate. I can then bump it and it will stay lit for a few minutes then go back out. Called the dealership and was quoted $850+ installed to replace the taillight. Its clearly an electrical fault... all the bulbs still illuminate when its on. Going to pull the taillight this weekend and check the connector. I thought it looked cool, but had no idea it would cost so much when it failed. I even have a comprehensive 100k warranty through Assurant (USAA), but it doesn't cover anything deemed "illumination", so I may be SOL.
Miami-Dade
Super Moderator
When I was in NYC last October saw several 2015 plus Livery Suburban's with blown headlamps..Was not happy to see that.
dbbd1
At this point at least, it sounds like a bad solder joint. Might be an easy fix.
sharksfan22
I just fell into the same issue. A little over a year ago, one of my taillights failed but was covered under warranty. The same light failed again, but is out of the 12mo/12k mle warranty so I had the privilege of spending $800 on a new taillight assembly. The dealer was polite about it and provided me the info to file a claim with GM.
sharksfan22
Looks like GMC is going to be reasonable here. They offered to pay half the price of the replacement - I took it as that's better than nothing and technically, they really have no legal obligation to pay anything.
vishnu619
Both of mine just went out, have the Ally extended warranty. Will call tomorrow and see what they say.
iLikeEggs
Potato!
Oregon, USA
It
LEDs are a stupid "solution" in search of a non-existent problem. Instead of a $2 incandescent bulb that needs replace every couple years, now it's a multi-hundred $ repair. I'd be trying to retrofit back to ordinary $2 lamps.
http://www.eenewsanalog.com/news/big-lie-about-led-lighting
The big lie about LED lighting
Scott Elder, principal engineer with Linear Technology discusses why LED lighting fails earlier than consumers might expect.
Goes hand in hand with the trend lemmings that jumped on the white tail lights band wagon. LED's is just taking the tail light stupid up another level. Your mileage may vary.
MiamiDubai
Well the dreaded has happened.
My passenger taillight is temperamental. Seems to only work at night.
Pulled the trigger and bought a set of Esky lights.
Buzarr
