depends which one's leaking?, does it have transmission cooler in front? and jeez napa is pricey, rockauto will be cheaper same part, those will come pre bent look and match it up same bends
1 has a trans cooler, the other doesnt. Look in your glovebox for rpo codesThe ones that are leaking are the 2 that run up to the cooler. I’m confused about the with or without rpo code
Better yet tell me, do you have a trailer brake controller, from the factory, by your left knee?
Look in your glove compartment and see if you see these 2 codes KNP K5L View attachment 188649
So k5l is out, do you see knp?No I don’t have a trailer brake controller
