willxfs
Hey Dkknaebel,
Can you tell me what VSS you replaced. Is this a speed sensor? On the transmission or the transfer case? I'm having a problem with the torque converter clutch randomly unlocking at highway speeds. Thanks!
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
Hey Dkknaebel,
I replaced the VSS that sits on the transmission. This is the rock auto part I used - ULTRA-POWER 5S4668. It sits on the left side of your transmission, easy enough to reach when it is on the ground. Just unclip the harness, and an adjustable wrench and you'll be good to go.
1BADI5
DMV
Are the brake calipers from a 3500 a direct bolt up to the 1500 and im guessing a nbs mc is the hydro boost upgrade right?
The MC I will be using will not be the hydro boost, its the standard MC from the NBS (02 Silvy)
jiggie
Installed my overhead console tonight. Even found the wires for the map lights tucked away so it was just a matter of cutting the holes for the rear clips, pulling the map light plug up to the front and swapping the rear heat/ac controls( i know mine works so keeping the other for back up). Headliner was a pita but got it done in a few hours. Here is the finished look and some along the way pics.
Buzarr
