#1taho
5150TAHO
niagara falls ont
Hah yeah...just ordered bilsteins...
What did you pay each ? I can get the 5100 for $140 cdn. Just trying to see what's the average is. And from what I can see there is two different 5100's part numbers ! Anyone know the difference? I read the description but could see the difference
jdpber
GOLD MEMBER
The America
not today but 2 days ago on Saturday. I replaced the Auxillary rear air resistor for the fan speed control. The 1 & 2 speeds were not working leaving only the 3 setting to work. Alternate/OEM Part Number(s): 12477721, 88986482 for $61 from RockAuto.. the process is very simple. remove the rear cargo net screw out nub, pop out the lower panel tree plug, remove the lower and upper door trim, remove the rear pillar trim, remove the 5.5mm bolt on the passenger door seat belt trim by the cup holder. now you can pop the rear corner of the lower cargo side panel out and access the regulator at the rear of the fan. You have 2 nut bolts and 3 wires to disconnect. MAKE SURE THE VEHICLE IS OFF!. reverse process and let that cold AC blast.
05Single
afraid of the dark
Pics aren't showing up :shrug:
bottomline2000
Dallas, TX
How does she drive now with the 4L80??
Man I only drove it thru my neighborhood and to the gas station. Wanted to get a feel for the converter and make sure the trans wasn't slipping. I have the worse combo of 3.42 gears and big wheels to run an 80e but I can already tell it not as bad as most say. I have a 10.5" converter that weighs 1/3 the factory unit that helps. I got some fantom codes popping up for abs C0279 and PCM 1810 that I'm trying to work thru with BB before really getting into it.
I did pump mods and the HD2 kit with sonnax pressure relief valve and shifting is smooth as butter so far. I'll post updates as its worked out.
TheAutumnWind
I got 4600s for $62 us on ebay
5100s likely come in varying lengths. Also keep in mind that the hd trucks have different shock mounts so dont get one of those. Also takenote that there is an old part # and a new part # for thw same shock.
5100s besides length are valved differently than 4600s btw. 5100s are digressive and 4600s are linear.
The two different front shocks in tbe 5100 series are:
Part Number: 24-185950
Series: B8 5100
Position: Front
Descriptor: For Front Lifted Height: 4-6"
Descriptor: With Crossmember Lift Kit
Descriptor: Without Police Package
Descriptor: Without Z55 Autoride Suspension Package
Collapsed Length (IN): 14.15
Extended Length (IN): 21.38
Collapsed Length (MM): 359.5
Extended Length (MM): 543
Old Part Number: BE5-B513
Old Part Number: F4-BE5-B513-H0
B8 5100 - Shock Absorber (click for more info)
Part Number: 24-186643
Series: B8 5100
Position: Front
Descriptor: For Front Lifted Height: 0-2.5"
Descriptor: With Torsion Key Lift
Collapsed Length (IN): 12.54
Extended Length (IN): 16.3
Collapsed Length (MM): 318.5
Extended Length (MM): 414
Old Part Number: BE5-C153
Old Part Number: F4-BE5-C153-H0
And thw rears are
Part Number: 24-185783
Series: B8 5100
Position: Rear
Descriptor: For Rear Lifted Height: 3"
Descriptor: Without ZW7 Premium Smooth Ride Nivomat Suspension
Collapsed Length (IN): 16.16
Extended Length (IN): 26.14
Collapsed Length (MM): 410.5
Extended Length (MM): 664
Old Part Number: BE5-6682
Old Part Number: F4-BE5-6682-H6
Old Part Number: F4-BE5-6682-H7
Old Part Number: F4-BE5-6682-H8
Part Number: 24-187237
Series: B8 5100
Position: Rear
Descriptor: For Rear Lifted Height: 0-1"
Descriptor: For Rear Lifted Height: 5" if using rear stock shock relocation bracket
Descriptor: If vehicle is equipped with ZW7 Premium Smooth Ride Nivomat Suspension you must purchase Bilstein spring part number 199021 in addition to the damper
Collapsed Length (IN): 15.55
Extended Length (IN): 24.33
Collapsed Length (MM): 395
Extended Length (MM): 618
Old Part Number: BE5-F265
Old Part Number: F4-BE5-F265-H0
agmanw8n
