MikeW
Just confirming that 00-06 Escalade roof racks, appliques and rear glass/3rd brake light are interchangeable with 00-06 our Tahoes......... Thanks -
Which year Esky gauge clusters swap into 04 Tahoe?
Sent from my LG-LS993 using Tapatalk
i have a nice console lid if anyone is interested grey
It depends on the year the glass came off of and the year of the truck the third light came off of. The 2002-2004 glass is different from the 2005/2006 glass hatch. If your tahoe's glass is 2002-2004, there won't be any holes in the glass and you will need to use adhesive to keep the esky third light on the glass. The 2005/2006 Tahoe and Yukon had a big plastic trim piece at the top of the glass, with screws going through the top to hold it on. Take that piece off and replace with the esky third. Then run the esky third wires down through the hole in the top of the hatch where the middle screw goes and plug into your Tahoe/yukon's third brake light wiring. And flip it backwards. For some reason the orientation of the wires is backwards on the esky third from the wires in the tahoe/Yukon.So all you need to do is remove the Tahoe third brake light and the rear glass will match right up? What about the wiring for the third brake light?
