Ftrsavage
Pittsburgh Pa
Tinted the taillights vht nightshade.... 2000 grit wet sand, 3 coats of vht nightshade and will wet sand again and buff and polish tomorrow until smooth and shiny like glass.... I also played around with the front lights with regular tint.... next is to open headlights and bumper lights to paint housing black and color match grille....
OK, here's how my day has gone:
Up--
got the Hoe back with the rust fixed and the HD Hood looking good. IMAG2224.jpg IMAG2226.jpgIMAG2227.jpg
Down--Had to replace the radiator. The side tank cracked. IMAG2237.jpgUp--
Got it fixed pretty quick. Cost me a little over $200.
Took it for a nice little ride.
Down---IMAG2263.jpgI think the trans is shot. 2nd whines out, doesn't go into 3rd. I'm mentally drained! Of course it happens on a holiday weekend.
Up--
got the Hoe back with the rust fixed and the HD Hood looking good. View attachment 82640 View attachment 82641View attachment 82642
Down--Had to replace the radiator. The side tank cracked. View attachment 82643Up--
Down---View attachment 82644I think the trans is shot. 2nd whines out, doesn't go into 3rd. I'm mentally drained! Of course it happens on a holiday weekend.
Feel like a yo-yo Tony?
bottomline2000
Dallas, TX
Up--
Have a shop check ur shift solenoids. One may have gone out. Had something similar happen. If you have reverse there's still hope. If not it may be a broken sunshell.
Up-
welcome to the HD hood club!
BADRIDES
Nice upgrade to tinting the rear lights
Oh yeah, to put it mildly.
Up-
I soooooo hope that's the case. Would/could that burn your trans fluid a little? The level is good, just a little brown. Doesn't smell that burned either.
bottomline2000
Dallas, TX
Anything is possible and I wonder if you got coolant in your trans fluid when the radiator cracked. It may have started slipping. That's why I run my trans cooler seperate and bypass the radiator..that may be harder to do up North.
Now that I think about it the trans runs thru the passenger side tank and your leak looks like the drivers side tank.
BigBee44
