gmc yukon no start
J
Jared839
Can you do me a favor and see if that black wire with the white stripe is coming out of your OBD2 sensor on the passenger side.
bunchz71
I do not see that wire anywhere in that area. I would start by charging your battery. When your battery is charged, I would test to see if it is a ground or pos wire. There should be no positive connectors like that other than your alternator and starter. I suspect that is a ground wire that mounts on one of the transmission bolts ? It could be coincidence that it is not blowing fuses because your battery is dead.
1. Charge you Battery
2. Test to see if positive or negative
if its a ground, it more and likely is not what caused your fuse to blow.
bunchz71
J
Jared839
This is the picture o wanted to send but didn't have wire is in top of image by dipstick1495588108449319488306.jpg 1495588108449319488306.jpg 1495588234711601477726.jpg
J
Jared839
This is behind the distributor in the middle. Feels like it is a ground. I will try and get a better pic.
Pretty much same wire there is no juice coming off of it when key is in on position
bunchz71
it almost has to be a ground that mounts to the transmission bolt. Did you try and put the voltmeter between pos of your battery and that wire >?
J
Jared839
Must be a ground but from what the voltmeter doesn't read until I put the negative on that wire when I put the pos on the battery
pmack
