Fosscore's 2006 Tahoe Build Thread
05Single
afraid of the dark
Just had a thought , do Silverado/sierra truck handles match up with ours? Different years? Or other vehicles ? For color options ...possibly grey or black.
Little fact for today , the dome lights are the exact same ones I had in my 2005 Dakota.
There are quite a few interior pieces that are used in other make vehicles. Not made by gm itself but made by the same outside company.
jerryjoe28
That Guy
cabot AR
Power Stop 1 Click Z23 Evolution Sport Brake Kit Upgrade.
29 March 2015
73K miles
Just finished my 4 corners brake rotors and pads upgrade. Looks really good.
I did a bit of research on the TYF and online then decided to go with the Power Stop 1 Click Z23 Evolution Sport Brake Kit.
This includes a complete set of cross-drilled and slotted rotors and high performance Evolution Sport Carbon Fiber/Ceramic pads.
http://www.powerstop.com/product/power-stop-z16-kit/#y=2006&mk=CHEVROLET&mo=TAHOE 2WD
FRONT : Z23-785REAR : Z23-974A for the 2WD model only. The 4WD model requires a different size rear pad. The drop down menu on Power Stops site will denote as such. I actually ordered via Amazon Prime as it was about $15 cheaper at the time. About $310 for everything which is the price point I wanted to be at.
My buddy offered to give me a hand as he has his own storage unit that he turned into a workshop for his own vehicles with every tool you could need.
Last week we put in a few hours on Sunday afternoon, only to get stumped with stubborn Torx bolts on the front calipers, broke an extension, found out we had the wrong size pads for the rear wheels then decided to regroup.
I ordered a new T55 Torx 1/2" socket driver for more torque from Amazon for $5.00, the correct 2WD size pads, replacement caliper guide pin bolts ($7.50 for a 2 pack from Advance Auto Parts) that have a normal bolt head, not the OEM frustrating Torx heads and we put the Tahoe up on his lift in his shop to have better access to everything from underneath.
You can see the hardware that came in the kit. Everything needed to do the change over. New rotors, new pads, new clips, new pin bushings (I utilized the OEM rubber boots as they were still in good condition) and high temperature lubricant that was included. Everything was labelled and packed well with installation instructions, break in instructions and the brake pads came in separate boxes with all associated hardware.
I unpacked the boxes and decided to paint the rotors as per Tony (NorcalSS) thread noted here to help retard the rust. See my OEM rotors for how bad they looked after 73K.
http://www.tahoeyukonforum.com/forum/showthread.php?t=49870
I used high temp Rustoleum with some matte black that I already had on hand for the base coats x 2 front and back and then top coated with 2 more coats of semi-gloss.
Everything came apart and went back together as it should, double checked and greased as needed. We ditched the Torx bolts for the above mentioned replacement guide pin bolts (even lowered on Tony's 3/5 kit, there is plenty of clearance with the new guide pin bolt heads and the upper control arm), had to bleed off a little brake fluid to retract the caliper pistons to accept the new brake pads. There wasn't a tremendous amount of wear, but the rear rotors did have some rust on the rotor and the pads on the inside of the rotor did not appear to be utilizing the entire rotor for stopping power. The bleed off only turned out to be a minimal amount as even after the break in runs, the master cylinder was still topped off.
I painted the calipers Duplicolor Silver to give them some pop.
After putting everything back together, I headed out for the break in procedure as outlined on the Power Stop box.
5 aggressive decelerations from 40mph to 10mph.
5 moderate decelerations from 35mph to 5mph.
Then I drove around for 5 minutes at low speed with very minimal braking to let the brakes cool off and then returned to my buddy's shop.
**As a further note, all the black spray paint that was on the face of the rotors, was gone after the break in period leaving the rotors clean, but the non-touched areas coated in semi-gloss black.**
The brakes felt better on the way home and they sure look great. There is a better feel on the pedal and at the wheels, but I still think it needs to have the brake fluid and power steering fluid flushed completely as many have noted on the TYF from other brake jobs. I hope to get that taken care of in the next few weeks.
well here I am again digging trough your build to see what you did for brakes lol. how do you like the powerstops now? how did that black paint hold up? I was looking into the EBC kit with the black rotors but the PS seem to get good reviews. even saw in one kit they give you a powder coated caliper as an upgrade 2
Fosscore
Fosscore
@jerryjoe28
Glad my build thread is still creating ideas. Hope to be adding to it some more. Lol
I like what the PowerStop had to offer in terms of all that you need coming together in one order, the price was right and I have been happy with the outcome in performance and looks.
My buddy helped with the install so that was free of charge.
Shortly after I did the upgrade to my OEM setup, I learned more about the NNBS upgrade which I probably would have gone ahead and done so. I know Red Rocket did the same thing, but he made the change out even after he had just upgrade with the the NBS size brakes.
I painted my new rotors and stock calipers with multiple coats before I installed them and followed the break in procedures to a "T" as described on the box.
I just refreshed them last month as they had gotten a little rough looking in spots.
They lasted pretty good.
I'm glad I did the upgrade but wish I had more knowledge about the NNBS upgrade with the bigger rotors at the time.
She stops perhaps a little better than stock, but still needs some coasting distance. If I did a foot to floor emergency stop I'm sure I could chirp the tires and send contents flying. My NNBS stops better even with the extra weight.
Hope that helps a bit. It was still a parts renewal at 75000 miles which is always a win. Sure I looked at BBKs but fawk the prices I just couldn't justify.
I could do many other mods and now with 2 trucks... well you know how that goes. :)
jerryjoe28
That Guy
cabot AR
@jerryjoe28
Lol thanks for getting back 2 me. Now u have me wondering about this nnbs upgrade! Guess I'll haft to do some research on that now [emoji36] . Not sure the cost difference to do that but it sounds promising......... btw I didn't get to go crazy with the 303 yet as I spent the truck time messing with the sub, but I did try it in a few small places and I think I'm going to love this stuff! I did the top of my fuse box just so I could get an idea of what it would do. WOW no residue and it looks great. Can't wait to do everything I can get it on now!
Sent from my SAMSUNG-SM-G900A using Tapatalk
jerryjoe28
That Guy
cabot AR
Well crap no I'm really curious about this nnbs upgrade..... I guess I just need to Google "nnbs brake upgrade on nbs" ?
fishcop076
