20hoe3
Just put cognito lift upper control arms, eBay keys, 2" coil spacer, and zone 1.5" body lift. Then run some 20x12 on 305/55R20
Nice! I never heard of cognito till now.
And replace CV joints constantly...
You can crank the keys a little without killing CVs. I'm not saying crank to max but run them at a slight negative angle maybe 1-1.5" lift.And replace CV joints constantly...
When I called Fabtech, they said they made it to where they basically lifted truck and while keeping factory suspension geometry. So, I figued well if its factory geometry what harm would be to add rear coil spacers and torsion keys. Wouldnt that be like adding that to a stock suspension set up?
The wheels I would like to go with is 20". The problem is idk what width and offset to go with.
yeah that is my worry too LOL. the suspension travel is perfect right now.
If he is cranking enough to need new uppers than it is going to be ugly under there.You can crank the keys a little without killing CVs. I'm not saying crank to max but run them at a slight negative angle maybe 1-1.5" lift.
Do you know what adding extra lift does to nearly every component in the front? The kit is designed for the way it is setup, you could probably get be with cranking slightly higher.
20" means nothing, you will likely have to go with a near stock offset to get even close to making this work. Like I asked before, take some pics, you may be fine with a little cranking. Take pics of the wheels turned both ways and check for clearance. Also what tire are you wanting to get? Not all measure out to 35" so that may be to your benefit.
