2015 Denali LED Fog Light Replacement
codeblackdanny
Miami, FL
Hey guys! So I recently purchased a 2016 GMC Yukon SLE, and I already upgraded the reverse, and license plate bulbs to 6000k LEDs and its definitely a big difference! The only thing i am having an issue with currently is with the fog lights. I am an amazon supporter as you guys call yourselves lol and the one that says fits doesn't fit. My current bulbs fog light bulbs have to be twisted to be removed, but the ones that came in are like the ones you guys post here that the base is a clamp on. are the 2015 fog lights different from the 2016, or how did you guys install those? i am so confused! and I have tried searching on vleds.com for fog lights, and for some reason can't see the model of the fog light bulb that works. any help would definetly be appreciated! Tomorrow I will be upgrading the low beam headlights to 6000k HID, im excited hahaha.
Slow5.0
Missouri
Early 15' use 5202 or H16 bulb late 15 and 16 use PSX26W
You need PSX26W https://www.amazon.com/PSX26W-Power...t Foglight Bulb for Car**&tag=viglink20600-20
That one will be 6000k with little bit more blue. You have to trim one of ears about 3mm. You will see if you put side by side. When installing it push harder that led into fog light housing. Btw i didnt have to remove anything to get to fog light bulbs. Just lay down in front of vehicle and put hand from behing bumper up high, and you will find connector, disconnect it and twist bulb counter clockwise
These guys have them in 5000 or 6000k http://www.xenondepot.com/PSX26W-LED-bulb-cree-p/xd-psx26w-led.htm
They also always have 10-20% discount
codeblackdanny
Miami, FL
You need PSX26W https://www.amazon.com/PSX26W-Power-White-Light-Foglight/dp/B00E6K9WE0/ref=sr_1_1?ie=UTF8&qid=1416534652&sr=8-1&keywords=PSX26W 30W High Power White 6 LED Fog Light Foglight Bulb for Car**&tag=viglink20600-20
Ohh ok! Awesome! Yes, this bulb looks more like the fog light bulbs that come from the factory. What do you mean about the trimming one of the ears 3 mm? It doesn't fit smoothly inside the housing?
Today I installed the HID headlights and they look amazing, but they do have that "Touch" of blue in them, even though I ordered them 6000k "crystal white" but they really make a huge difference, i'm very happy with them.
Thank you for your help! @Slow5.0 really appreciate it.
Slow5.0
Missouri
6000k will have some blue. 5000k hould be pure white
Trimming one ear to match OEM only apply to Urcell PSX26W since i only got those. I may get Xenondepot 5000k PSX26W and they maybe have same ears like OEM
humer101
NJ,USA
My suggestion is taken the bulb out and is very easy to see exactly what you want.
Slow5.0
Missouri
Codeblackdanny how hard or how did you remove headlights in order to replace lo/hi. Any instructions?
I think there is hidden tab on bottom of headlight like one on 07-14 Tahoe and goes behind bumper and lot of people breaking that tab
Slow5.0
Missouri
I just got PSX26W in 5000k from http://www.xenondepot.com/PSX26W-LED-bulb-cree-p/xd-psx26w-led.htm and they are white. Compared to Uxcell PSX26W from amazon they are much brighter and better match to the D3S and led DRL
And these leds from Xenon depot are real PSX26W bulbs, one from Uxcell are P13W
Here is some pics
Xenon Depot 5000k on passenger side, Uxcell 6000k on driver side
lynxnova
New Jersey
I have a question, I just had 6000k hid (bulb only) installed on my LTZ... I can't get the beam to focus on to the center street... I had them removed and checked to see if they were installed correctly which they were but I still can't seem to get them aligned... now I did adjust them to the right hight and even tried to lower the alignment but the beam pattern seems to be non existing.... the driver side beam pattern is about 50% visible while the passenger side is 20% visible... could it be the bulbs that could be no good (cheap) ?... I had went to a local shop and I they put some hid bulbs that I never heard of
Sent from my SM-G920V using Tapatalk
Ihaveatahoetoo
