Wired up my 1/2 din eq tonight
Max
Mile High
Denver
Holy crap what a difference. I have zero static and my minimal ground noise has vanished completely. I'm having a friend fabricate a trim panel since that's what he does all day and I don't have the tools anymore, will post pics once I get that done along with sound deadening my doors. I can't believe how much cleaner it sounds with only an 8 band eclipse eq. Should sound even better with the doors deadened and the dual batteries wired up, swear I have different speakers in the truck now I've never heard this kind of dynamic range from them before :rocking:
tast101
Colton, CA
I think I'm going to start to purchase stuff for a dual battery. I want to get that out of the way, since I like to be outside and listen to my music alot.
M
Max
Mile High
Denver
All I need is an isolator, gonna order one at work tomorrow so I don't have an excuse. Gotta mount this big bastard under my backseat cuz it won't fut under the hood.
M
Max
Mile High
Denver
It looks like crap just chillin in my 6disc changer slot, I'll post some pics one I get the trim panel done.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i was thinkin of doing this too, but since i have a double din having the eq right below the hu i already have...hmmm...might look better where you have it. Can't wait to see the pics for steeling the idea...lol.
M
Max
Mile High
Denver
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
is he making a trim ring just for around the eq or to replace the entire denali panel for that section? jw
M
Max
Mile High
Denver
No idea, probably just a bezel and trim out the edges of the stock piece a bit. I'm sure it will look good, he's a perfectionist so I'm sure it will be sweet when completed.
wade
i am a noob, max what year Nali you got? and also, my 03 Nali doesnt have that little fuel/trip screen down there... whats that all about?
diffrnt
Say...What!
MS
Hey, I know what you mean about the EQ. I have always ran an EQ with any of my systems. It makes a world of difference. I even got my boy running the same Clarion EQ as mine.
M
Max
Mile High
Denver
Dropped off my dash panel and eq trim piece at my boy's shop friday, should have it back monday or sometime next week. He's plastic welding the trim piece, then bondo, then paint. Should turn out pretty sharp, will post pics when I get it all in. This should tide me over until I get the rest of the stereo sorted out with a w505 2din, delete the dic, buy the imprint sound processing, and mold in a wideband o2 monitor.
lilsolo68
tyler,tx
i have a 2000 yukon with the cassete player toward the bottom of the console. what size is it, 1 din or 1/2 din and are there any kits out there that i can use to fit a 1/2 din 8 band eq in it? also how difficult is it to hook one up?
M
Max
Mile High
Denver
Pretty easy to hook up but it depends on what kind of eq you use. I haven't seen the cassette decks in awhile so I couldn't tell you what size, if I had to guess it's 1/2 din or 1/2 the size of your standard head unit.
M
Max
Mile High
Denver
Turned out real nice, this should get me by until the 2din and imprint processor get installed next year
puckhead
CO
lookin good! I need to get one now, I have some road noise i want to get rid of. how much did it run ya and whats the hook up like? fairly easy I imagine
M
Max
Mile High
Denver
I traded him some sway disconnects, eq was free. Easy hookup just tap a few wires and run a dedicated ground. I may end up running the sub off the deck and only running highs through the eq since it doesn't make much difference for my lows. No more bright ridiculous tweeters tho, I might buy a bigger amp for the fronts now too.
JeffK
