Windows
Holt50
Hey guys my 97 Yukon 4 door 4x4 364,856 miles. Windows will only roll up with the driver side switches Any ideal what the heck the problem is? I changed the switches on the driver door before the other windows stopped working. Also my check engine light does not come on when key is on.
2010gmcyukon
Midwest
If the check engine light doesn't come one...the bulb may have been pulled/burnt out. You can pull out the cluster fairly easily to check the bulbs.
Holt50
Holt50
Already checked that. It worked fine until a few MONTHS after I got it smoged
Holt50
Holt50
You don’t have the child lock on accidentally, do you?
No I do not. Right after I replaced the main switches on the driver's door the other 3 don't work with ther on switch. Only work from the drivers switches
Holt50
Holt50
Ok fixed the check engine lite but still can't roll up windows with there own switch only from the drivers side. I have power at all three doors but they won't roll up or down.
TollKeeper
Brighton, CO
If you still have your old switch, that is where I would start. Put the old one back in, and check for operation. Since you changing the switch is when it all started, its likely related.
losloho02
