window issues
Z-56 Hoe
What do I do????
Houston
2002 the driver side window wont move. Power cable is good no kinks, we replaced the switch, checked the fuse, and regulator. Still not working any impute?
YukonXL04
The Riverboat
Arlington, TX
Is it in a bind? That's what is sounds like it everything else checks out? Maybe it's jammed up somewhere
ladorn45
If the the scissors are working meaning the motor is going up and down that means you have a snapped cable or a broken plastic piece that holds the cable in place. So this allows your motor to move up and down while window stays in place. If the cable is fine then that motor should not go up or down with out the window
briannorris
