where does seafoam go
olforrester
i bought some from advanced and he said the hose coming out of brake booster good idea?
hassoun
Germantown, MD
what truck do you have ? just be careful. some brake boosters are hydrolics and not vacuum. your best choice is locate where the pcv valve is and disconnect that hose and use it as a suction for half of the sea foam bottle. the other half will go on a quarter tank of gas. if you have more its better to wait until you get to quarter tank. if you tell me what year and model you have i'll be able to help you locate the pcv valve hose.
HotCarl
ID/WA
On the OBS you can do either the PCV valve line or the brake booster vac line. I have done both lines before, but some say on the 5.7 Vortecs those lines only go to two cylinders, so the way to get the full treatment is put the whole bottle in the gasoline. Personally, I have done some in the vac lines and some in the gas, and some in the oil.
kope
Northwest Montana
I always do .33 in the fuel, .33 in the upper intake via, brake booster, and .33 in the oil.
Just remember if you do use it in your oil to only run the engine about 25 miles then change the oil and filter.
bai78
Surviving
Dallas, TX
You should do the brake booster line as well as through the throttle body. This will disperse it to all cylinders.
MetalStorm
Just Sea Foamed for the first time, 169,000 miles. Brake booster vacuum line, gas tank, and crank case. Not all that impressed. I got one good puff of smoke as I was dumping it in the vacuum hose, and very briefly when I restarted it after 25 minutes and then put about 30 miles on.
crmzendrgone
M town Arizona
DO yo do a lot of high way driving?
Just means that yours wasn't that carboned up. mine didn't smoke at all but I know it worked.
Did the wifes 03 TB and it smoked like a turkey and she has 90k but mostly city or stop and go.
See with highway or high rpm driving doesn't allow as much carbon build up.
MetalStorm
Yeah I kinda figured that. I bought the truck 3 years ago with a bout 145,000 highway miles, and since then I have put on almost 25,000 NYC/Long Island miles. Even still, 169,000 is STILL 169,000 miles! Ya can't tell me there's no carbon in there! I'm just gonna have to monitoring the mpg's during the next fill up.
Danny_Z56
Franklinville NY
Run the entire bottle through the brake booster hose....If you have a PCV line to your intake than use that.In my case i really had no other choice than the brake booster hose.
Make sure the motor is good and warmed up/hot.
You may need someone to give the vehicle a "little" gas while taking in the seafoam.This will help keep the motor from stalling.Once the entire can of seafoam is gone shut engine off....let sit for a good 15 minutes.
After 15-20 minutes,start it and rev it in your driveway or take it for a spin.If you take it for a drive make sure you get on it from time to time,helps clean sh*t out.
When i did my Tahoe @ 138K i got plenty of smoke....
IMO if you dump any of this stuff in your crank case or gas tank you are just wasting money.Their are better products for this,like autoRX,GM cleaner,ect....IMO Seafoam should be ran through nothing but your intake.Thats were it seems to work best.
Conedaddy
