What's the best Intake/CAI kit??
Volant1
Volant guy
Upland, CA
Thats the difference between 8in of filter and 8ft theres more surface area for dirt to cover and nothing for it to stick to
That doesn't make any sense, 100k? I clean my filter every 5k, takes 20 minutes.
NoChrome
I think Im with max on this one, sure I dont clean my filter every 5k but, 100k is a long, long time. I dont care how bad ass your air filter is, it is eventually gonna run out of places for dirt to stick or its just letting smaller stuff through that would normally clog one up.
Volant1
Volant guy
Upland, CA
It isnt a Volant filter, its a donaldson, same flute that is in the black hawk helo, your not dealing with a cotton, poly or paper filter its nano fiber, you do not service the filter so there is no break down in microns like serviceable filters, its .001 micron from start to end like I stated above there is nothing for the dirt to stick to so it does not build up, we also put a downward angle on all of the filters so large sand and dirt fall back out of the top, also you do now that every time you service a filter your letting in more dirt right?
Max
Mile High
Denver
I'll stick with my aem that collects mad dirt every time I clean it :cheers:
hoserty
Ft. Rucker, AL
Here is a little food for thought i just picked up this intake off eBay for 67.00 shipped may not be the best or the nicest but it has been working great for me.
Here is the eBay link for the item......
http://cgi.ebay.com/ebaymotors/ws/e...0385991747&viewitem=&sspagename=STRK:MEWNX:IT
and here is a few pics of it installed
These pics are of the intake installed on my 07 Denali
dynamitekid
manteca ca
hey i got a afe Magnum Force air filter box, with afe pipe.. put a airaid throttle body on and makes a differnce on my 07 yukon.. also put 1 chamber flow master with 2 tips out the side.. sounds great
wot_denali
UaE
Air aid box keep the stock tube and save your money
JennaBear
Resident Ninja
San Diego, CA
The stock tube is what you should be changing, as that is where all the restriction is. Check out the resonator on that thing.
Blkout02
All Over
What's better arm brute force with oil free filter or aem cai or a kn cai or are they just all pesonnel peference
JennaBear
Resident Ninja
San Diego, CA
Anything that changes out that stock tube will be just fine. Go with what you want, they all perform pretty close to the same.
Blkout02
All Over
Is there much a difference between a dry filter and one that contains oil?
madmac
Cheap Alternative to CAI?
Back in the bad old days, resourceful hotrodders simply replaced the air filter with one that was too tall. This left a gap all the way around the air filter lid, bypassing the restrictive snorkel, and thereby increased air flow to the carburetor at a cost of, well, nothing. A four-barrel carb made a wonderful howling noise. For you youngsters, a carburetor was a device... never mind.
In that spirit, when I had a 1975 Volvo with Bosch fuel injection and no money for accessories, I simply drilled dozens of holes in the air filter canister. I have no idea if it got better mileage or more power, but it seemed to have better throttle response off idle and sounded stronger.
Don't get me wrong. I love those polished tubes and dashing red filters, but has anyone tried drilling holes or cutting openings in the stock air box? Of course it would no longer be a true cold air intake, but then most of the ones on the market look like they pull hot air from the engine compartment, too.
mikeb33
Inverness, IL
I did something similar on my '05 Tahoe. I detailed it here: http://www.tahoeforum.com/showthread.php?t=12062
I now have a '07 Denali and haven't yet looked to see if I can do this again.
Excon11
Banned
North Dakota
Im looking at a fujita cold air intake for mine. Any body herd good/bad things about it? Thanks.
mikeb33
Inverness, IL
I looked at the stock tube and it doesn't seem that bad. I do see the ridiculous looking resonator, but how does that hurt? The resonator is an acoustic sound canceling design, how does it hurt airflow? I would think ample diameter and smooth bends would be the most important, which the stock tube seems to have.
madmac
By resonator, if you are referring to the closed extension on the air intake projecting toward the driver side, the purpose may be this.
I am no automotive engineer, but if I remember correctly, Yamaha uses a similar arrangement on their ram air intake for the R1 or R6. The idea is that it stores a volume of air held in reserve to be used to aid in transition for sudden throttle openings. But I could be wrong, I often am.
mikeb33
Inverness, IL
If that is true, I can't see a downside to it.
I still think it is a sound canceling thing. My 05 was louder with the Airaid jr tube, basically the same tube, without the extra chamber, or resonator.
I'd like to see a dyno with and without.
JamesinAbilene
