What size front leveling kit for '07 Denali?
ToddEdge
Trophy Club, TX
Guys, I'm brand new to the world of GM and I've searched this site for a few hours but, need some advice...
Just picked up an '07 Yukon Denali AWD. It has the air adjustable rear shocks, if that matters...
I'm only looking to make it sit level and don't want to raise the rear anymore than it already is. I see front kits ranging from 1" to 2.5". From what I can gather, to make it sit as close to level the concensus seems to be 2" in the front with no rear modifications? Is that correct? I don't want the "cali lean" but, also want to eliminate as much of the rake as possible.
Thanks,
Todd
InTruckDesign
SW CT,
The best way to determine what height kit you want is to measure it...measure from the center of the wheelwell opening to the ground both front and rear...that will give you the difference as it sits now. When I spec them out for a client I always round the number down...always better to have a very little bit of rake than a sagging rear.
Conedaddy
