Weird noise
Billy_ocean04
Michigan
Well I have a question before I drop my truck off at the shop. When ever I'm in drive and I pull off kind of fast. I hear a clanking noise coming from the rear. The only time I hear it is when I'm pulling of and sometimes when I'm turning. It sounds like two metal plates clanking together. Has anyone else experienced this? I thought I would ask before I go to the shop.
Billy_ocean04
Billy_ocean04
Michigan
The last time I went to the oil change place and they showed me the diff oil and it didn't look dirty. Thanks. I might change it for the heck of it. I hope that is all that it is.
---------- Post added at 08:22 PM ---------- Previous post was at 08:02 PM ----------
I was scared that it was the trans or something. Lol. I'm still gonna go see what the shop says
350VortecSSCT
Westport, CT
Lead Springs is a definite...high speeds and turning are all forms of shift of weight. If it were your rear end, there would be more clanks at slow speeds and turns...meaning, your whole rear differential is shot...Look for rust or forms of dirt coming off the leaf springs onto your wheels...with a clank there is crank
Billy_ocean04
Billy_ocean04
Michigan
Thanks guys. I'm gonna check into all of the possibilities. Then take it to the shop on my day off from work. Oh also I hear some weird noise back there if I'm in drive and I let off the brake and just let roll. The diff fluid didn't look bad when I checked it. I'm gonna change it though
---------- Post added at 07:26 PM ---------- Previous post was at 07:23 PM ----------
To amswer your ? PH99. Yes I have a little vibration in the rear at highway speeds
kjlegend
Milwaukee
+1 I'm having the same problem it sounds like. Keep us posted! I'll do the same.
Billy_ocean04
Billy_ocean04
Michigan
im gonna get it checked out when i get off work today hopefully. are u joints expensive to replace???????????
Billy_ocean04
Billy_ocean04
Michigan
The other thing I'm worried about now is today when I shifted from park to reverse I heard the noise a little bit. Imgoim to the shop in a couple of hours.
STL_Denali
Did you ever get the problem with the rear nosie you were having checked out? Wondering what it turned out to be.
Johnny Racer
Chicago, IL
Kind of an old thread but my Yukon has always had what I refer to as the dredded GM Honk when I matt the gas from a stop. As far as I know that is the rear springs wrapping up on themselves. Might be wrong here but thats what I was thinking.
rossida
