Ordered mine from here http://www.tahoeyukonforum.com/forum/showthread.php?t=20070&page=4 and just got it installed. Figured I would make a new thread so I dont clutter the other one.
With everything I added it was 650 for the install. Took them just about 10 hours, said they ran into trouble with existing wiring or something. Everything is good though and works good. They did glass break, tilt, backup battery, pizo alarm, hooked something up to moniter the hood, and the transponder thing you have to get for it all to work. They also have it so my defrost comes on under 55*. Seemed a little high of a temperature but whatever, anyone know if the temp is easy to cahnge?
They also said they couldnt make my heated seats come on under a certain temp because they run on 9 volts or something. Anyone know if this is true?
I also dont like the blue led that flashes for an hour or whatever after you arm it. There a way to turn that off? If not I might paint over it with black paint or something. Otherwise I like it and it works great! Need to read through the manual again and check everything out. Sorry for the long post
